MathJax does not render until page refresh
Hi all,
I have linked Mathjax to my ghost blog (version 1.24.5) by linking
<script src='https://cdnjs.cloudflare.com/ajax/libs/mathjax/2.7.4/MathJax.js?config=TeX-MML-AM_CHTML' async></script>
to the {{ghost_foot}} code-injection.
When I try to load my page by clicking the blog entry in blog home, mathjax does not seem to render. It does render after a page refresh however.
You can find my blog post at https://www.codeon.tech/ with a title of “Solving The Lane-Emden Equation”. How ever directly going to the blog post through it’s link seems to work just fine.
I googled around a bit and found a github question in mathjax issue here.
If there is a way to fix this issue please let me know.
update: I tried to add a page-reload script to the blog post (as a dirty-solution) and it didn’t work as well. I figured, it is possible that with blog-posts ghost doesn’t run js scripts (probably).
Finally I figured it was a problem with my ghost theme (theme being implemented with ajax calls to load blog posts can cause mathjax to not render synchronously).
Queuing typeset action with MathJax.Hub.Queue(["Typeset",MathJax.Hub]);can fix such an issue.
For more read MathJax Docs on typeset here.
