I have setup Cloudinary Ghost storage adapter for image optimisation and serving images as AVIF where possible. The default configuration worked fine.
However, Pagespeed kept flagging Properly size images as one of the main reasons for a lower score on my site.
To fix this, I tried to setup responsive image transformations following the official Cloudinary Node.js documentation.
I changed my configuration as follows:
"fetch": {
"fetch_format": "auto",
"responsive": true,
"width": "auto",
"crop": "scale",
"quality": "auto",
"secure": false,
"cdn_subdomain": true
The default Ghost Image Optimisation has been disabled as required.
"imageOptimisation": {
"resize": false
However, there seems to be no change in the widths on Pagespeed Insights.
While the image URL shows the parameters:
https://res-4.cloudinary.com/da9mvldpq/image/upload/c_scale,f_auto,q_auto,w_auto/v1/blog-images/2--Resource.jpg
The attribute for the image has the original width and height
<img src="https://res-4.cloudinary.com/da9mvldpq/image/upload/c_scale,f_auto,q_auto,…" class="kg-image" alt="" loading="lazy" width="1500" height="741">
I do not know if the problem is in my configuration or if the adapter does not support these functions.
P.S. I have next to no experience in code and have been piecing things together by searching. Any help is much appreciated!
What’s your URL? thedavincistoat.com
What version of Ghost are you using? 4.26.1
How was Ghost installed and configured? Digital Ocean 1-click image
What Node version, database, OS & browser are you using? Node v14.18.2, Ubuntu 20.04.3 LTS, Mac OS Monterey, Microsoft Edge 96
