You have configured Ghost with the bare domain, so using www won’t work. You need to decide whether you want to use non-www or www, and then setup Google and Ghost correctly.
Google robot testing tool default redirects to my other website, and I have tried to check the blog through this. So I used this tool to check my robots.txt.
There is no error showing my robots.txt file.
I have cleared the cache from Cloudflare and re-submit it didn’t work.
This will be the problem you need to solve. Google can’t see the website you’re trying to index. Using a different tool isn’t going to help fix Google.
