I’m trying to have Ghost dynamically populate the icon in based on the navigation slug. However, it’s telling me this isn’t valid. Is there a way to make this work the way I’m intending?
{{#foreach navigation}}
<li class="{{slug}}{{#if current}} nav-current{{/if}}">
<a href="{{url absolute="true"}}" title="{{label}}" class="dropdown-link">
{{> "icons/{{slug}}"}}
<span>{{label}}</span>
</a>
</li>
{{/foreach}}
Is this a partial living in partials/navigation.hbs ?
And are you calling it as {{navigation}}, not as {{> navigation}} ?
Although the two look about the same, {{navigation}} gets all the context set right, while {{> navigation}} does not. (You can pass in variables to either one.)
UPDATE:
(reads again) Oh, hang on, it’s probably that you’re trying to dynamically call that partial. I don’t think that’s supported. Instead do {{> icon" icon=slug}} and then from partials/icon.hbs, you’re going to need something like:
{{#match icon “=” “heart”}}
{{> heart}}
{{else match icon = “tree”}}
{{> tree}}
{{/match}}
Which will be a pain to set up, but you only have to do it once if you abstract it into its own partial.
