What’s your URL? mrengineer13@live.com
What version of Ghost are you using? 3.14.0, tried installing 1.x but it wasn’t compatible with node
What configuration?
server {
listen 80;
listen [::]:80;server_name site. com;
root /website_p/ghost; # Used for acme.sh SSL verification (https://acme.sh)return 301 https://mrengineer13 .com$request_uri;location / {
proxy_pass http://127.0.0.1:2369;}
skip favicon.ico
location = /favicon.ico {
access_log off;
return 204;
}location ~ /.well-known {
allow all;
}client_max_body_size 50m;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name site .com;
root /website_path/ghost/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
ssl_certificate /etc/letsencrypt/mrengineer13.com/fullchain.cer;
ssl_certificate_key /etc/letsencrypt/mrengineer13.com/mrengineer13.com.key;
location / {
allow all;
- What browser? Brave/FF/Chrome
In the browser I’m getting ERR_SSL_PROTOCOL_ERROR.
When I curl -I the domain I get 502 error. When I try to check the journalctl -e I get unrelated logs.
What steps could someone else take to reproduce the issue you’re having? Have existing site and then install new one
I have been trying to update ghost, I’m on 0.3.x, so I am trying to migrate domains, I tried to migrate first to 1.x but my node version is too new so I’m trying to install version 3 clean and try to migrate my posts.
I am running nginx so I removed the old domain from /sites-enabled/, the old let’s encrypt certs for the www. domain - along with the A-records from my DNS (Digital Ocean).
Ghost.service won’t start and the errors in /content/logs are empty, any ideas?
