Ghost SSL Problems
  • What’s your URL? kisacabilgi.net
  • What version of Ghost are you using? 5.47.1
  • What configuration? ubuntu 20
  • What browser? chrome
    log:
    OS: Ubuntu, v20.04.6 LTS
    Node Version: v16.20.0
    Ghost Version: 5.47.1
    Ghost-CLI Version: 1.24.0
    Environment: production
    Command: 'ghost install 5.47.1'
Message: Failed to restart Nginx.
Stack: Error: Failed to restart Nginx.
    at NginxExtension.restartNginx (/usr/lib/node_modules/ghost-cli/extensions/nginx/index.js:262:19)
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
Original Error Message:
Message: Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#'  nginx -s reload
nginx: [emerg] cannot load certificate "/etc/letsencrypt/kisacabilgi.net/fullchain.cer": BIO_new_file() failed (SSL: error:02001002:system libra>
Stack: Error: Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#'  nginx -s reload
    at makeError (/usr/lib/node_modules/ghost-cli/node_modules/execa/index.js:174:9)
    at /usr/lib/node_modules/ghost-cli/node_modules/execa/index.js:278:16
    at async NginxExtension.restartNginx (/usr/lib/node_modules/ghost-cli/extensions/nginx/index.js:260:13)
You might try running ghost setup ssl again and post the output, please?
The error above is truncated, but can you check that you actually do have a certificate at /etc/letsencrypt/kisacabilgi.net/fullchain.cer? I think that’s a missing file error…?
These files exist
well, the folder exists, anyway - might want to go into it and look for the actual file.
But assuming it’s there, you need a more useful error message. Try starting nginx on the command line, maybe?
Oh, sorry, that wasn’t a command. Try sudo nginx reload – maybe, depending on how you installed it.
It specifically told you what to do to see the problem details. Did you do that?
I did this setup on 3 different VDS providers, I got the same error in all of them.
Could it be a problem on the ghost cli side?
Let’s encrypt the rate limit for the second time, I’m about to go crazy now.
Does this post help?
It worked for me when I was setting up a new server and it crashed and burned after installing the Let’s Encrypt cert.
I ran into the same issue and through my post - I wasn’t aware of the one Theo mentions - we were able to resolve the issue. Looks like the same problem caused by a recent difference in the way that a DigitalOcean 1 click install names the folders that include the SSL certs.
