What’s your URL? This is the easiest way for others to help you
bowiesensei.com -
What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
Ghost version: 5.53.1
And -
DigitalOcean 1 click and configuration myself. -
Node v16.20.1
MacOS Monteray
Chrome -
N/A -
I’m getting a message You are running an outdated version of Ghost-CLI. It is recommended that you upgrade before continuing. Run npm install -g ghost-cli@latest to upgrade.
However, when I run npm install -g ghost-cli@latestas the ghost-mgr user I get the following.
npm ERR! code EACCES
npm ERR! syscall rename
npm ERR! path /usr/lib/node_modules/ghost-cli
npm ERR! dest /usr/lib/node_modules/.ghost-cli-no3HtXlj
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, rename '/usr/lib/node_modules/ghost-cli' -> '/usr/lib/node_modules/.ghost-cli-no3HtXlj'
npm ERR! [Error: EACCES: permission denied, rename '/usr/lib/node_modules/ghost-cli' -> '/usr/lib/node_modules/.ghost-cli-no3HtXlj'] {
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'rename',
npm ERR! path: '/usr/lib/node_modules/ghost-cli',
npm ERR! dest: '/usr/lib/node_modules/.ghost-cli-no3HtXlj'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/ghost-mgr/.npm/_logs/2023-07-05T17_23_30_492Z-debug-0.log
