Personalized urls for topic (yaml file)
Hi guys,
My yaml file is like this:
routes:
collections:
/services/:
permalink: /services/{slug}/
filter: tag:services
template:
- home
- index
permalink: /{slug}/
template:
- home
- index
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
After the file upload i don’t know how to personalize the page domain/services and how to create new pages inside /services for example domain/services/marketing. Because when i go to stories creation settings “Post URL” nothing appear and i’m with tag “services” in filter. I don’t know what i’m doing wrong…
Could i please have your help?
Kind Regards
Collections only own posts, not static pages.
If you create a post with a tag “services”, it will appear under /services/.
Side note: Please use inverse filters, see docs.
Hi Kate,
Yes that’s true thanks for your help :slight_smile:
Now i have tested and i have post not published on the timeline and taged by Servises, that appears like domain/services/marketing/.
Although i prefer static pages, do you know how can i configure yaml file for that effect?
Kind Regards
I guess you could define a custom route for that.
routes:
  /services/marketing/:
    data: page.marketing
Let use know if it works.
Hello Kate,
This don’t work for me :worried:, but i don’t know why …
I hope you can provide some leads on this :smile:
Notes: Now i have a page named by “domain/marketing/” and i need to put this page inside services “domain/services/marketing/”
Now i have done the flowing experiments:
  1. Like you have said:
 routes:
  1. With some changes
routes:
     slug: marketing
     redirect: false
  1. Result in multiple errors on the website
    routes:
      /services/marketing/: marketing
Unfortunately i have same result (1 and 2) of "404 Page Not Found, but it acquired the new path “domain/services/marketing/”, it seams unable to find the page.
Do you have any clue? What’s happening down here?
Kind Regards
Can you please share the full routes.yaml? I am not sure i can follow the steps. Thanks :slight_smile:
Hi Kate,
I just have this on the file (complete):
 routes:
     slug: marketing
     redirect: false
 collections:
   /services/:
     template:
       - home
       - index
     permalink: /{slug}/
     template:
       - home
       - index
 taxonomies:
   tag: /tag/{slug}/
Thanks
routes.yaml
 routes:
     template: marketing
 collections:
   /services/:
     template:
       - home
       - index
     permalink: /{slug}/
     filter: tag:-services
     template:
       - home
       - index
 taxonomies:
   tag: /tag/{slug}/
marketing.hbs
{{#page}}
  {{content}}
{{/page}}
Hi kate,
Now it seams working but unfortunately my page from “domain/services”, it’s a blanc page only with website structure how can i edit this for a normal static page with general services description? Do i need to add in routes also with new template?
With this structure:
routes:
     template: marketing
It’s working but it seams having a redirection, what’s the effect on the search engines? What link they index? domain/marketing or domain/services/marketing, because i desire index the second one.
Can i have this with no redirection at all, directly to destiny “domain/services/marketing” ?
Why this happening?
Kind Regards
