Posts flipping between working and 404 after publish
We have been using Ghost for a while now and it works great, but I updated to v2 not so long ago and now when I publish a new post it generally flip flops between working and 404ing for a about an hour before working correctly (sometimes I can get around this by un-publishing and re-publishing the post but that doesn’t always work.)
I am currently on Version 2.16.4
Has anyone else experienced this issue and/or have a fix?
I suspect you have a multi-instance setup, which is not supported:
I’ve not heard any reports of this happening on single instance setups, so if you do have only 1 instance, please provide as much detail as possible about your Ghost setup so we can help more.
