Primary-author is empty
primary-author outputs nothing. I am using the following code. How can I access the first author?
{{#primary_author}}
<div class="author">
    <a href="{{url}}">{{name}}</a>
    <span class="bio">{{bio}}</span>
</div>
{{/primary_author}}
Hi @mkn,
You need to be in the post context for this to work.
So on a homepage listing posts:
{{#foreach posts}}
  ..your code
{{/foreach}}
Or if you are in a post then:
{{#post}}
  ..your code
{{/post}}
Maybe you can share the larger context of where you are trying to implement it.
