I have added Prism JS syntax highlighting to my theme.
I compiled prism on the pris js site to include various languages and some plugins (including copy to clipboard and line numbers)
On post.hbs I have added to the top:
To the bottom I have added:
Here is the output on the front-end:
As you can see, the line 1 is blank and the last line has no number (it should be line 12)
I have checked the code entry and there is no blank line at the top.
Anybody come across this before or know of a solution?
Hey there. That’s odd, looks like it could be misaligned and something is pushing the code down. Do you have a link to the page so I can debug it? Could be solved with some CSS
Thanks for the reply.
It was indeed the theme’s css that was adding padding to the pre>code
Sometimes we overthink these things and miss the obvious:-)
If you could share your found solution it might help others!
It was theme specific on a custom theme.
So, if someone comes across a similar problem in future, always check the theme css for padding on the pre and code elements
