My local version of Ghost is already active.
I generally solve by restarting the PC, but not now.
I rebooted the pc 2 times, still can’t start local Ghost, it is already active.
There are no node processes, neither from the Task Manger nor from the Resource Monitor.
> ghost start
Ghost is already running! For more information, run:
ghost ls
> ghost ls
│ Name │ Location │ Version │ Status │ URL │ Port │ Process Manager │
│ ghost-local │ ~\ghost │ 3.40.5 │ running (development) │ http://localhost:2368/ │ 2368 │ local
> ghost stop
× Stopping Ghost: ghost-local
A CliError occurred.
Message: An unexpected error occurred while stopping Ghost.
OS: Microsoft Windows 10 Pro, v10.0.19042
Node Version: v14.15.1
Ghost Version: 3.40.5
Ghost-CLI Version: 1.15.3
Environment: development
Command: 'ghost stop'
Additional log info available in: C:\Users\username\.ghost\logs\ghost-cli-debug-2021-01-14T22_51_21_355Z.log
You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
> ghost doctor
Found a development config but not a production config, running in development mode instead
√ Checking system Node.js version
√ Checking current folder permissions
Instance is currently running
i Validating config [skipped]
√ Checking memory availability
√ Checking binary dependencies
√ Checking free space
> ../../debug.log
Stack: Error: An unexpected error occurred while stopping Ghost.
at C:\Users\username\AppData\Roaming\npm\node_modules\ghost-cli\lib\utils\local-process.js:124:39
at processTicksAndRejections (internal/process/task_queues.js:93:5)
at async Instance.stop (C:\Users\username\AppData\Roaming\npm\node_modules\ghost-cli\lib\instance.js:303:9)
Original Error Message:
Message:
Error: Killing process 3088 failed: Command failed with exit code 255: taskkill /f /t /pid 3088
at Array.map (<anonymous>)
at fkill (C:/Users/username/AppData/Roaming/npm/node_modules/ghost-cli/node_modules/fkill/index.js:128:9)
at async Instance.stop (C:/Users/username/AppData/Roaming/npm/node_modules/ghost-cli/lib/instance.js:303:9)
Stack: AggregateError:
at fkill (C:\Users\username\AppData\Roaming\npm\node_modules\ghost-cli\node_modules\fkill\index.js:128:9)
