This morning, I cannot launch my local Ghost install
http://localhost:2368/ don’t work
I try to restart Ghost with “ghost restart”
× Restarting Ghost
A CliError occurred.
Message: An unexpected error occurred while stopping Ghost.
This is the log file
OS: Microsoft Windows 10 Professionnel, v10.0.19042
Node Version: v12.19.0
Ghost Version: 3.37.1
Ghost-CLI Version: 1.15.2
Environment: development
Command: ‘ghost restart’
Stack: Error: An unexpected error occurred while stopping Ghost.
at C:\Users\xtric\AppData\Roaming\npm\node_modules\ghost-cli\lib\utils\local-process.js:124:39
at processTicksAndRejections (internal/process/task_queues.js:97:5)
at async LocalProcess.restart (C:\Users\xtric\AppData\Roaming\npm\node_modules\ghost-cli\lib\process-manager.js:34:9)
at async Instance.restart (C:\Users\xtric\AppData\Roaming\npm\node_modules\ghost-cli\lib\instance.js:326:9)
Original Error Message:
Message:
Error: Killing process 8592 failed: Process doesn’t exist
at Array.map ()
at fkill (C:/Users/xtric/AppData/Roaming/npm/node_modules/ghost-cli/node_modules/fkill/index.js:128:9)
at async LocalProcess.restart (C:/Users/xtric/AppData/Roaming/npm/node_modules/ghost-cli/lib/process-manager.js:34:9)
at async Instance.restart (C:/Users/xtric/AppData/Roaming/npm/node_modules/ghost-cli/lib/instance.js:326:9)
Stack: AggregateError:
at Array.map ()
at fkill (C:\Users\xtric\AppData\Roaming\npm\node_modules\ghost-cli\node_modules\fkill\index.js:128:9)
