Problem in Multiple Ghost sites on shared hosting
Hi everyone. I have run into a problem while hosting multiple ghost sites on a shared hosting (namecheap stellar plus). These are low traffic non-membership sites.
I have a main domain abc.com with shared hosting.
I have two addon websites pqr.com & xyz.com on which I want to install ghost.
Their respective directories with 755 access are /home/abc/pqr & /home/abc/xyz
Installing ghost on xyz successfully
  • creating a node 18 app
  • in the terminal, installing ghost cli, then rm -rf *, then ghost install local
  • changing the url in the config file from localhost to the website url
I am repeating the same steps for pqr, I get this error on ghost install local step:
Ghost was able to start, but errored during boot with: Access denied for user ‘root’@‘localhost’ (using password: NO)
On checking, it is not able to generate ghost-local.db in the folder /contents/data/
What do I do?
(If I do ghost install instead of ghost install local, I get the sudo-root error which might be due to shared hosting instead of VPS, so I went the ghost install local way).
Sounds like a permissions problem. I’d really carefully check that the permissions for that folder are correct for the user you’re running ghost install local as. Since you have a working install, you might find it helpful to compare.
It’s definitely possible to run multiple local installs at once, each in its own directory and with its own port.
I think you already know this, but only MySQL 8 is supported for production. That doesn’t mean you can’t set up a local install and treat it like production, but do be aware that you’re doing something that’s not intended, so you’re at higher risk of things breaking.
Turns out the problem was database. The installation was not able to create ghost-local.db file.
I changed sqlite3 to mysql and ghost start was successful but the site gave 503.
I had to copy a local ghost-local.db file and the site finally worked as expected.
