With the latest version of Ghost there is a problem with embedded HTML codes in a HTML card. I use prism.js as code syntax highlighter.
HTML raw code
<pre><code class="language-cpp">/* C++ */
#include <iostream​>
int main() {
std::cout << "Hello World!";
return 0;
</code></pre>
But the HTML source code of the output looks like
!--kg-card-begin: html-->
#include <iostream>
int main() {
return 0;
</iostream></code></pre>
<!--kg-card-end: html-->
The expanded HTML Codes < > leads to problems . In this case iostream is missing, for other code snippetes rendering problems are the result.
