Problems install the AWS S3 Plugin
I’m trying to install the following AWS S3 plugin for ghost GitHub - spanishdict/ghost-s3-compat: Read and write images from S3 in the Ghost blogging platfrom. I’m using the latest version of ghost. I added to the following to config.production.json
  "storage": {
    "active": "ghost-s3",
    "ghost-s3": {
      "accessKeyId": "****",
      "secretAccessKey": "****",
      "bucket": "test-bucket",
      "region": "us-west-2"
under content/storage there is directory called ghost-s3-compat as directed by the instructions.
then I get the following error:
Unable to find storage adapter ghost-s3 in ,/var/lib/ghost/content/adapters/,/var/lib/ghost/versions/3.41.5/core/server/adapters/.
Okay, not sure why it’s not finding it but fine, let’s install it as instructed, I’m putting the library now in both content/storage and content/adapters/
ghost_1  | 'node_modules/ghost-s3-compat/.jshintrc' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/.jshintrc'
ghost_1  | 'node_modules/ghost-s3-compat/.npmignore' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/.npmignore'
ghost_1  | 'node_modules/ghost-s3-compat/CHANGELOG.md' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/CHANGELOG.md'
ghost_1  | 'node_modules/ghost-s3-compat/LICENSE' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/LICENSE'
ghost_1  | 'node_modules/ghost-s3-compat/README.md' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/README.md'
ghost_1  | 'node_modules/ghost-s3-compat/index.js' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/index.js'
ghost_1  | 'node_modules/ghost-s3-compat/package.json' -> 'content/storage/ghost-s3-compat/ghost-s3-compat/package.json'
ghost_1  | 'node_modules/ghost-s3-compat' -> 'content/adapters/ghost-s3-compat'
ghost_1  | 'node_modules/ghost-s3-compat/.jshintrc' -> 'content/adapters/ghost-s3-compat/.jshintrc'
ghost_1  | 'node_modules/ghost-s3-compat/.npmignore' -> 'content/adapters/ghost-s3-compat/.npmignore'
ghost_1  | 'node_modules/ghost-s3-compat/CHANGELOG.md' -> 'content/adapters/ghost-s3-compat/CHANGELOG.md'
ghost_1  | 'node_modules/ghost-s3-compat/LICENSE' -> 'content/adapters/ghost-s3-compat/LICENSE'
ghost_1  | 'node_modules/ghost-s3-compat/README.md' -> 'content/adapters/ghost-s3-compat/README.md'
ghost_1  | 'node_modules/ghost-s3-compat/index.js' -> 'content/adapters/ghost-s3-compat/index.js'
ghost_1  | 'node_modules/ghost-s3-compat/package.json' -> 'content/adapters/ghost-s3-compat/package.json'
I also tried to configure the app via ENV variables instead.
storage__active=ghost-s3
storage__ghost-s3__accessKeyId=
storage__ghost-s3__secretAccessKey=
storage__ghost-s3__region=us-west-2
storage__ghost-s3__bucket=testing-bucket
Neither of them worked.
On the other hand if I try to use the GCS plugin. I installed the plugin to the same location and it works fine. I feel like I’m missing something.
Any help is appreciated.
Also, doing this on the docker image if that makes any difference on the answer.
the same with me, I lose 1 day for this issue. After that, I try gcs in the docker file. It works oke
Yeah GCS works great but still was hoping to get s3 support figured out. :frowning:
Maybe just update the documentation saying S3 isn’t supported if that’s the case?
