Hello! Somehow my admin part is cached. For example at the same time I see different content inside admin part inside Safari and Chrome. I’ve switched off caching inside Cloudflare for /ghost*. The same I do have for nginx:
expires -1;
add_header Cache-Control “private”;
Do you have any suggestion what can be the reason?
The whole content of the admin part like: settings, list of posts, night-mode and etc. contains outdated/cached versions. By using another instance of browser I see updated version when open first time the admin part. But after change it became outaded and I see the original version which I’ve opened before. I do not use clustering of multi-instance setup. Just simple digitalocean server with Cloudflare on top.
I think this may have something to do with your service worker. I had the same problem which went unnoticed until I started adding posts. I have a slightly different check for if the URL contains /ghost/ than you.
const cacheName = "blogCache";
const offlineUrl = "/offline/";
* The event listener for the service worker installation
self.addEventListener("install", (event) => {
event.waitUntil(
caches.open(cacheName).then((cache) => cache.addAll([offlineUrl]))
* Is the current request for an HTML page?
* @param {Object} event
function isHtmlPage(event) {
return (
event.request.method === "GET" &&
event.request.headers.get("accept").includes("text/html")
* Fetch and cache any results as we receive them.
self.addEventListener("fetch", (event) => {
if (!event.request.url.includes("/ghost/")) {
event.respondWith(
caches.match(event.request).then((response) => {
// Only return cache if it's not an HTML page
if (response && !isHtmlPage(event)) {
return response;
return fetch(event.request)
.then(function (response) {
// Dont cache if not a 200 response
if (!response || response.status !== 200) {
return response;
let responseToCache = response.clone();
caches.open(cacheName).then(function (cache) {
cache.put(event.request, responseToCache);
return response;
.catch((error) => {
// Check if the user is offline first and is trying to navigate to a web page
if (isHtmlPage(event)) {
return caches.match(offlineUrl);
