Hi.
For some reason, I have trouble installing the latest 4.59.1 version locally.
That is to say, the installation went well, I can create an admin account but when I do ghost stop I cannot get it running again. ghost start always gives me this:
✖ Checking system Node.js version - found v18.16.0
ℹ Ensuring user is not logged in as ghost user [skipped]
ℹ Checking if logged in user is directory owner [skipped]
✔ Validating config
One or more errors occurred.
1) SystemError
Message: The directory /home/myuser/ is not readable by other users on the system.
This can cause issues with the CLI, you must either make this directory readable by others or install node and Ghost-CLI in another location.
OS: ubuntu, v7 Horus // this is elementaryOS 7 Horus
Node Version: v18.16.0
Ghost Version: 5.49.1
Ghost-CLI Version: 1.24.0
Environment: development
Command: 'ghost start'
EDIT: And now this - when a ghost is not running, ghost restart works, while at the same time ghost start produces the error. What’s with that??
On the same note, I don’t understand why Ghost installed locally won’t work on any Nodejs version than the one that it’s been installed with. How does one update the Nodejs on the local installation? I tried adding a newer version in package.json but with no luck.
Cheers.
