- What’s your URL? This is the easiest way for others to help you
blog.talescript.com - What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
ghost version
Ghost-CLI version: 1.25.3
Ghost version: 5.75.1 (at /var/www/talescript)
And
It was installed using the ghost install guide for ubuntu
How to install & setup Ghost on Ubuntu 20.04 or 22.04 -
node --version
v18.17.1
cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
mysql --version
mysql Ver 8.0.35-0ubuntu0.20.04.1 for Linux on x86_64 ((Ubuntu))
Firefox
cat ghost_error.log
https://careers.ghost.org
- Inspecting operating system
- Checking for deprecations
[13:25:03] Checking for Ghost-CLI updates [started]
[13:25:03] Checking for Ghost-CLI updates [completed]
[13:25:03] Ensuring correct ~/.config folder ownership [started]
[13:25:03] Ensuring correct ~/.config folder ownership [completed]
+ sudo systemctl is-active ghost_blog-talescript-com
/usr/lib/node_modules/ghost-cli/lib/ui/index.js:148
throw new errors.SystemError('Prompts have been disabled, all options must be provided via command line flags');
SystemError: Prompts have been disabled, all options must be provided via command line flags
at UI.prompt (/usr/lib/node_modules/ghost-cli/lib/ui/index.js:148:19)
at Socket.<anonymous> (/usr/lib/node_modules/ghost-cli/lib/ui/index.js:248:22)
at Socket.emit (node:events:526:35)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Readable.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23) {
options: {
message: 'Prompts have been disabled, all options must be provided via command line flags'
logMessageOnly: undefined,
help: 'You can always refer to https://ghost.org/docs/ghost-cli/ for troubleshooting.',
err: {}
Node.js v18.17.1
I have a bash script to update ghost.
#!/usr/bin/bash
DIR=/var/www
sudo -u ghostUser bash << EOF
cd $DIR/talescript && ghost update && \
cd $DIR/johnswebsite && ghost update
EOF
as an aside, I’m not too sure if using sudo in the script is a good practice or not
I’ve added a nopasswd into visudo
ghostUser ALL=(ghostUser) NOPASSWD: /home/ghostUser/bin/update_ghost.sh
The cronjob was created using root sudo crontab -e
25 13 * * * /usr/bin/bash /home/ghostUser/bin/update_ghost.sh >> /home/ghostUser/bin/ghost_error.log 2>&1
After an extensive search, this is the closest workable suggestion I have managed to find but I am not entirely sure if it is the correct solution [Using Ghost-CLI programatically · Issue #721 · TryGhost/Ghost-CLI · GitHub](https://Using Ghost-CLI programatically) (honestly I didn’t quite understand the proposed solution)
**EDIT:**So, I changed from using the root crontab to using the users crontab crontab -e and managed to get rid of the errors, however, it is not updating to the new version of ghost
cat ghost_error.log
[15:19:05] Checking for Ghost-CLI updates [started]
[15:19:05] Checking for Ghost-CLI updates [completed]
[15:19:05] Ensuring correct ~/.config folder ownership [started]
[15:19:05] Ensuring correct ~/.config folder ownership [completed]
