What’s your URL? This is the easiest way for others to help you
https://techmunchies.org -
What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
Ghost-CLI version: 1.24.0
Ghost version: 4.48.9 (at /var/www/ghost) -
Ghost was installed on DigitalOcean through the automated process there. The droplet I am using was created through the ‘Ghost droplet’ feature back in ~2021 -
Node version for both root and ghost-mgr user: v16.19.1 -
When using most ghost xxx commands, a different error shows up. The main ones are:
ghost doctor:
Checking systemd node version - found v12.22.12
One or more errors occurred.
Checking system compatibility [skipped]
Checking for a MySQL installation
- sudo systemctl is-active ghost_techmunchies-org
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
Checking systemd unit file
Warning: Ghost is running with node v12.22.12.
Your current node version is v16.19.1.
- SystemError
Message: Ghost v4.48.9 is not compatible with Node v12.22.12
Help: Check the version of Node configured in /lib/systemd/system/ghost_techmunchies-org.service and update it to a compatible version
OS: Ubuntu, v18.04.6 LTS
Node Version: v16.19.1
Ghost Version: 4.48.9
Ghost-CLI Version: 1.24.0
Environment: production
Command: ‘ghost doctor’
ghost backup / ghost start (happens at the same stage - when starting the daemon):
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
System checks failed with message: ‘Missing package(s): nginx’
For local installs we recommend using ghost install local instead.
? Continue anyway? Yes
System stack check skipped
Validating config
Checking free space
- SystemError
Note:
Manually going in MYSQL and setting the lock to 0 bypasses this, but then I receive an about an invalid token somewhere in the cjs module.
