Hi! How to make when you post about for example music this post is placed on the homepage and music category by clicking the menu of the same name? What should be written in the routes.yaml? Thanks!
This should work out-of-the-box. For instance, if you tag a post under music, the post will appear on the home page, and in the tag archive https://your.blog/tag/music.
Is this want you want, or are you seeking something else?
