Receiving Payments In India As An Individual
Stripe Does Not Allow Individuals In India To Receive Payments.
The bank is not an issue… Stripe is. Stripe needs the user to be a registered business to receive international payments. And since Ghost is not Indian, Indian payments are also restricted.
You can try out at https://blog.sushantshah.dev/
To enable export transactions, you must do the following when submitting your account application:
  1. Opt in to exports: In the account application, check the applicable box under the ‘I am exporting products to customers located outside India’ section. If you don’t opt in, you’ll only be able to make export charges in test mode. This option is only available for users with legal entity sole proprietorship, company, and LLC. (individuals are excluded)
