?ref parameter being added to links
Many links across the site content have ?ref=photomojo.au querystring appended. I’m not sure why.
This breaks the links using the javascript protocol that I’d like to use to invoke the chat box.
The link I paste is: javascript:void(Tawk_API.toggle())
The link that appears is: javascript:void(Tawk_API.toggle())?ref=photomojo.au
The latter breaks the Javascript.
Is this something I can turn off?
This feature is called “Outbound Link Tagging” and can be disabled in the analytics page of your Admin dashboard (https://{site}/ghost/#/settings/analytics)
That being said, the tagging being applied to inline javascript is probably not expected behavior :slight_smile:
Thank you! Disabling that feature did remove the tag from the javascript and now it’s working.
It looks like the issue with javascript: urls getting the ref treatment might be fixed in an upcoming release :slight_smile:
