Does anyone know if it’s possible to integrate a referral system like sparkloop into Ghost? I want to create a referral mechanism for the newsletter like MorningBrew or the hustle.
Thanks!
Thanks!
I see the integration with FirstPromoter. But it’s not straightforward. Does this referral system go into emails in ghost?
There’s also the integration with Viral Loops which seems a little more straightforward. I don’t think any of them are great solutions though. Worth remembering as well that Morning Brew’s program is custom built - so it’s clean because it was built like that.
There are integrations with both FirstPromoter and Viral Loops.
FirstPromoter is generally better suited to monetary referral programs, where you give affiliates a monetary commission for each referred customer.
Viral Loops is mainly better suited if you’re running a rewards based referral program, where you give affiliates physical or digital rewards.
Read more about the considerations of referral programs for publishers here: Newsletter referral programs explained
