Remove Authors and Tags from sitemap
Hi, is there a way to disable authors and tags from being included in sitemap.xml?
Thanks in advance.
Hey Solomon! This is work is currently in-progress and can be tracked here:
Awesome. Thanks.
Hi @John a quick question about sitemap. Is it possible to regenerate the sitemap? It was generated before I have installed SLL certificate and the links in sitemap are all non secure “http”.
In fact all I need is to add a /s/ to all non secure http links in sitemap, so if someone could tell me where file lives to make the changes manually I’d really appreciate it.
Thanks in advanced.
Sitemaps are generated dynamically! Be sure to update the URL and restart ghost :slight_smile:
Thanks.:heart_eyes:
