Remove date and feed title in Edition
I’m using the Edition theme and would like to remove:
  • the date on individual posts and also in the feed
  • the feed heading words (currently “The Works”) on the home page
Also if anyone has suggestions for other themes I might use if it appears that I am minimising “Edition” so much a simpler theme might be appropriate.
TIA
Site is here: https://sjhay.ghost.io
Hi @SJH!
Check this code into Code injection:
<style>.feed-header-wrapper,.feed-date,.feed-length::before,.single-meta-date,.single-meta-length::before{display:none}</style>
Thanks so much for this…
My ignorance in these matters knows no bounds, if I want to keep the reading times, do I just remove .feed-length and .single-meta-length from the code?
(edit) I see that with your code, the reading times remain. Ignorance is not always bliss…
Also, is there an order for things to be put into the Code Injection? I already have some code changing the font and my Google verification code. Can this go between them?
Thanks again.
There’s no conflict as long as the style codes have their <style> ... </style> tags. If you have a lot of code within these tags, you can group them into one. However, there’s no issue if they are separated.
I just noticed that in “Related Posts”, the date is still present. I guess there is more code to add to remove it? Something about feed-date?
To remove the date from this section, add the .feed-calendar class to the previous code.
Added before .feed-date and everything worked as expected.
Thank you for your patience.
No problem, I’m glad I could help you out in some way :)
