MPAQ
April 3, 2026, 10:38pm
1
This is driving me insaine and is probly something simple:
And
How was Ghost installed and configured? from ghost-cli
What Node version, database, OS & browser are you using? Debian 12,MariaDB 10.11.14, FireFox
What errors or information do you see in the console? When connecting to /ghost/
My config file is:
“url”: “http://localhost:2368 ”,
“server”: {
“port”: 2368,
“host”: “localhost”
“database”: {
“client”: “mysql”,
“connection”: {
“host”: “xxx.xxx.xxx.xxx”,
“user”: “xxx”,
“password”: “xxx”,
“database”: “xxx”
“mail”: {
“from”: “‘MPAQ’ admin@mpaq.org ”,
“transport”: “Direct”
“logging”: {
“transports”: [
“file”,
“stdout”
“process”: “systemd”,
“security”: {
“staffDeviceVerification”: true
“paths”: {
“contentPath”: “/var/www/ghost/content”
NGINX:
server {
listen xxx.xxx.xxx.xxx:xx;
server_name blogs.mpaq.org ;
location / {
proxy_pass http://127.0.0.1:2368 ;
client_max_body_size 50m;
Please tell me I’m just getting old and blind
MPAQ
April 6, 2026, 3:23pm
2
I have tried https://blogs.mpaq.org , http://blogs.mpaq.org and a lot of other things but this thing is still giving the same error with the different URLs. PLEASE help
Try setting the URL in your config file to https://blogs.mpaq.org
MPAQ
April 6, 2026, 4:20pm
5
Thank you so much for responding. I think I tried that to but got the same problem. I’ll try it again.
be sure to restart ghost afterwards :)
MPAQ
April 6, 2026, 4:33pm
7
Yep and this is what comes up now, I thought I’d tried that too…
The page isn’t redirecting properly
MPAQ
April 6, 2026, 6:06pm
8
I set the URL in config to https://blogs.mpaq.org and it stopped working for users, set to http://blogs.mpaq.org comes up for the users.
Could it have something to do with nginx config???
That normally occurs when you’re missing the x-forwarded-proto header in your ngind config. Note that you will want to fix this since setting the url as http will lead to weird (or maybe not weird as well) errors in the future
MPAQ
April 6, 2026, 10:56pm
10
Ok, and the above NGINX hasn’t changed so???:
server {
location / {
MPAQ
April 7, 2026, 7:26pm
11
GOT IT!!!
It seems multiple errors starting with NGINX so here is my config for anyone with this problem, NGINX wouldn’t let me do anything other then 443
server {
listen xxx.xxx.xxx.xx:443 ssl;
server_name news.mpaq.org ;
ssl_certificate /etc/apache2/ssl/fullchain.pem;
ssl_certificate_key /etc/apache2/ssl/privkey.pem;
location / {
proxy_set_header Host $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “upgrade”;
proxy_set_header X-Forwarded-For $remote_addr;
