Im using the latest version of the Casper theme on ghostpro.
Is there a way to add a required checkbox to the signup flow?
Need this so subscribers agree to the terms.
For a little more context, i will have a members only download page with a list of downloads.
Even something as simple as a required checkbox on the specific page that has to be checked at least once before members can download the files.
Hopefully this makes it a little clearer
One approach here would be to create a custom membership flow. However, this isn’t trivial to implement and would require some effort to customize your theme:
Here’s another solution that you can implement per page. This will only show the file download element after a user has checked a box.
First, create a custom HTML element in the editor. Add this:
<input id="consent" type="checkbox">
<label for="consent">
<span>☑</span>
<span>☐</span>
I consent
</label>
You can update the “I consent” text to fit your needs.
Then, add your file.
Finally, on the post sidebar, add this CSS to the Code Injection header.
<style>
.kg-file-card {
display: none;
#consent {
display: none;
label span:first-child {
display: none;
#consent:checked ~ label span:first-child {
display: initial;
#consent:checked ~ label span:last-child {
display: none;
#consent:checked ~ .kg-file-card {
display: flex;
</style>
Here’s the result:
Note that the file is just hidden with CSS, which means someone could bypass the check by altering the CSS.
I though about using a solution like this, but the ability to bypass it, doesn’t work. There really should be a way to add a checkbox to portal sign up flow.
ICYMI. This feature just dropped and may be of interest:
