Ghost Version: 4.13.0
If you access this URL (https://writtenby.adriengiboire.com/2021/09/08/fixed-ip-for-wsl-instances/), you’ll see big empty spaces with only written Untitled. These are the placeholders for images.
The web console shows this:
I don’t understand the Mixed Block reference.
Still the address is directly accessible: https://writtenby.adriengiboire.com/content/images/size/w1000/2021/09/Untitled-3-1.png
And if I manually integrated the image using this URL, it works as expected: https://writtenby.adriengiboire.com/content/images/2021/09/Untitled-3-1.png
I proceeded that way for a previous post I met the same issue with.
EDIT: I read about “Mixed Block” and I understand the browser block the content from loading because the original URL is in HTTPS but the media is load via HTTP.
Now, the question is: Why is the media loaded via HTTP by default?
The Ghost URL must be
It’s been so long since I’ve set this site up that I forgot about the
