This actually fixed the SEO issue and the title, but it completely breaks the load more functionality so my page can only load 8 posts and thats it. The whole pagination/load more functionality doesn’t work when I add the routes option above.
Does anyone have any ideas how I can fix this issue and get Collections to show SEO data and not break everything.
Not sure if this is going to help, but I tried accessing the page data directly from the collection, but it still breaks the ability to load more posts. Absolutely devastated about this. 1 months work and what is the point if Google can’t find the page…
At the moment the only way I can resolve the issues is to create a custom default.hbs file. This allows me to hardcode the page title and seo data. It also has allowed me to keep the load more script working.
No idea how else to solve this but disabling the collection is not possible, plus if I just use the routes option I still run into load more issues.
Hmm, that’s not good. I can see that you’ve also opened a support issue. If we can’t get this resolved here then it might be best to switch to the support ticket.
Are you at all able to share what you have so far? If it’s not the conflict between routes and collections, which I feel like it most likely is, then it might be the theme not catering for infinite loading. Do you get any errors when scrolling to the bottom of the page? It’s very hard to debug this without seeing it
Hi David, can you tell me if by setting up collections what Schema Ghost includes into the code? Do you have an example I can see that shows the collection of post so I can see the code?
Sorry, I’m not sure I understand what you’re asking for? If you want to see what Ghost produces when you create a custom collection you might want to set up a local version to try it for yourself
It might not be relevant, but Schema.org for tags is injected into every post as keywords on Ghost, and I was wondering if collections are handled differently.
