Anyone encounter an issue installing a secondary domain with SSL using the ghost-cli?
I get this error when trying to install SSL for another subdomain.
OS: Ubuntu, v16.04
Node Version: v8.15.0
Ghost-CLI Version: 1.9.9
Environment: production
Command: ‘ghost setup nginx ssl’
An error occurred.
Message: ‘This library (validator.js) validates strings only’Stack: TypeError: This library (validator.js) validates strings only
at assertString (/usr/local/share/.config/yarn/global/node_modules/validator/lib/util/assertString.js:11:11)
at isIP (/usr/local/share/.config/yarn/global/node_modules/validator/lib/isIP.js:20:30)
at NginxExtension.setupSSL (/usr/local/share/.config/yarn/global/node_modules/ghost-cli/extensions/nginx/index.js:94:13)
at Task.task (/usr/local/share/.config/yarn/global/node_modules/ghost-cli/lib/commands/setup.js:79:48)
at Promise.resolve.then.then.skipped (/usr/local/share/.config/yarn/global/node_modules/listr/lib/task.js:167:30)
at
