Hello everyone! Nice to join your community!
I am trying to set up the ghost as a subfolder.
What I have
Ruby on Rails server
Hosted on Heroku. I am not sure if I can share its URL, so let it be rails-server. herokuapp. com (sorry for spaces, i’ve done this to aviod forum 3 urls per post limit). In front of Ruby on Rails server, I have an Nginx server with the following config:
server {
listen <%= ENV["PORT"] %>;
server_name _;
keepalive_timeout 5;
client_header_buffer_size 12k;
location /blog/ {
client_max_body_size 10G;
resolver 1.1.1.1 8.8.8.8;
proxy_pass https://ghost-blog.herokuapp.com/;
proxy_redirect off;
proxy_set_header Host rails-server.herokuapp.com;
proxy_set_header X-Forwarded-Host rails-server.herokuapp.com;
proxy_set_header X-Forwarded-Proto https;
location / {
proxy_redirect off;
proxy_pass http://app_server;
client_max_body_size 15m;
Ghost server
Running as node application on another Heroku server. Let’s assume that the server with ghost is located at ghost-blog. herokuapp. com. Config was originated from here: GitHub - cobyism/ghost-on-heroku: One-button Heroku deploy for the Ghost blogging platform.. The only two small changes I made are the upgrade of ghost version to 2.2.0 (i will explain why 2.2.0 a bit later) and ‘url’ in config is https ://rails-server. herokuapp .com/blog.
Problematic
This setup is working very fine(I mean all is OK - site browsing, posts creating, email sending and so on) except for one thing. When I invite a user and he visits an invitation URL he sees a blank screen. With the following errors in the developer console.
After some investigations, I have found the following issue: when I try to visit the welcome post URL https ://rails-server.herokuapp.com/blog/welcome/ all is OK. But when I visit https ://rails-server.herokuapp.com/blog/welcome it redirects me to https ://rails-server.herokuapp.com/welcome. Same issue with the assets. When I visit links (with asset loading errors) in the console I see that all of that links are forwarding me to the https:// rails-server.herokuapp .com/path-to-the-asset (without /blog). And I think that it’s wired each to
And last thing: why I am v2.2.0: because at higher versions I have the errors I described in this GitHub issue.
Does anybody have some ideas about what to do? I am struggling for a few days on this issue and will appreciate any help.
Sorry again for spaces in the URLs.
