How do I use the MetaData component in the TryGhost Gatsby Starter.
import React from 'react'
import PropTypes from 'prop-types'
import { StaticQuery, graphql } from 'gatsby'
import url from 'url'
import config from '../../../utils/siteConfig'
import ArticleMeta from './ArticleMeta'
import WebsiteMeta from './WebsiteMeta'
import AuthorMeta from './AuthorMeta'
* MetaData will generate all relevant meta data information incl.
* JSON-LD (schema.org), Open Graph (Facebook) and Twitter properties.
const MetaData = ({ data, settings, title, description, image, location }) => {
const canonical = url.resolve(config.siteUrl, location.pathname)
const { ghostPost, ghostTag, ghostAuthor, ghostPage } = data
settings = settings.allGhostSettings.edges[0].node
if (ghostPost) {
return <ArticleMeta data={ghostPost} canonical={canonical} />
if (ghostTag) {
return (
<WebsiteMeta data={ghostTag} canonical={canonical} type="Series" />
if (ghostAuthor) {
return <AuthorMeta data={ghostAuthor} canonical={canonical} />
if (ghostPage) {
return (
<WebsiteMeta
data={ghostPage}
type="WebSite"
title = title || config.siteTitleMeta || settings.title
description =
description || config.siteDescriptionMeta || settings.description
image = image || settings.cover_image || null
image = image ? url.resolve(config.siteUrl, image) : null
return (
<WebsiteMeta
data={{}}
title={title}
description={description}
image={image}
type="WebSite"
MetaData.defaultProps = {
data: {},
MetaData.propTypes = {
data: PropTypes.shape({
ghostPost: PropTypes.object,
ghostTag: PropTypes.object,
ghostAuthor: PropTypes.object,
ghostPage: PropTypes.object,
}).isRequired,
settings: PropTypes.shape({
allGhostSettings: PropTypes.object.isRequired,
}).isRequired,
pathname: PropTypes.string.isRequired,
}).isRequired,
title: PropTypes.string,
description: PropTypes.string,
image: PropTypes.string,
const MetaDataQuery = (props) => (
<StaticQuery
query={graphql`
query GhostSettingsMetaData {
allGhostSettings {
edges {
node {
title
description
render={(data) => <MetaData settings={data} {...props} />}
export default MetaDataQuery
I’ve seen it used like this
