If I place
<title>{{meta_title}}</title>
<meta name="description" content="{{meta_description}}">
In my <head> element (editing the theme manually, not via code injection), gscan compains:
Errors
Important to fix, functionality may be degraded.
- Error: The usage of {{meta_description}} in HTML head is no longer required
Files: default.hbs
However it’s still referenced in the docs (Ghost Handlebars Theme Helpers: Meta Data) and if I remove it, some marketing tools start complaining. My choice is currently between breaking continuous delivery and receiving warnings from marketing tools.
Can I get some clarification on what to do regarding this? Why was it removed? Is Ghost supposed to add the HTML code without my intervention?
- What’s your URL? https://input.sh
- What version of Ghost are you using? 3.25.0
And
- How was Ghost installed and configured? Pretty much following the Ubuntu install docs.
- What Node version, database, OS & browser are you using? node v10.15.3, MariaDB 10.1.44, Ubuntu 18.04.
- What errors or information do you see in the console? N/A
- What steps could someone else take to reproduce the issue you’re having? Explained above.
