I updated Ghost to the latest version, but when accessing my url on browser “https://ryan-fernando.com” but it says that the site is not secure.
Plus, when I access https://ryan-fernando.com/ghost there’s a huge banner that I can’t get rid of, even when updating multiple times. " Critical security update available — please update Ghost as soon as possible. Details here."
Please help, I think that might be the reason why my site is deemed not secure.
The reason you (and I) see the warning is that the site isn’t configured correctly for https, and the installed certificate is invalid.
How did you setup https? You don’t appear to have used the Ghost options that setup nginx and install LetsEncrypt certificates. The certificate comes from zerossl.com.
You should be able to sort this by running ghost setup ssl. If you wish to use an alternative certificate you’ll need to get an up-to-date certificate and manually configure nginx.
Okay, I now understand that Ghost uses ZeroSSL not LetsEncrypt (I use neither and wasn’t aware of this change), so the certificate should be fine, except for the fact that it hasn’t auto-renewed.
Common Name (CN) ryan-fernando.com
Organisation (O) <Not Part Of Certificate>
Organisational Unit (OU) <Not Part Of Certificate>
Common Name (CN) ZeroSSL RSA Domain Secure Site CA
Organisation (O) ZeroSSL
Issued On Saturday, 23 October 2021 at 01:00:00
Expires On Friday, 21 January 2022 at 23:59:59
Can you run…
sudo crontab -u root -l
…and share the output. I’m uncertain if certbot works with ZeroSSL, but you should be able to renew the certificate with acme.sh -f -r -d https://ryan-fernando.com.
Your nginx config could be improved, too, since http requests do not redirect to https.
[Sun Feb 20 22:28:20 UTC 2022] Return code: 1
[Sun Feb 20 22:28:20 UTC 2022] **Error renew www.ryan-fernando.com.**
[Sun Feb 20 22:28:20 UTC 2022] _error_level='1'
[Sun Feb 20 22:28:20 UTC 2022] _set_level='2'
[Sun Feb 20 22:28:20 UTC 2022] The NOTIFY_HOOK is empty, just return.
[Sun Feb 20 22:28:20 UTC 2022] **===End cron===**
