I see a lot of SLOW_GET_HELPER error in the logs. I am using Ghost Version 3.20.3 with Lyra theme with no customization.
Attaching the logs for reference
{“name”:“Log”,“hostname”:“example.com”,“pid”:17402,“level”:40,“err”:{“id”:“d3e2d200-c1aa-11ea-b4ff-f76af3262d77”,“domain”:“https://example.com”,“code”:“SLOW_GET_HELPER”,“name”:“HelperWarning”,“statusCode”:500,“level”:“normal”,“message”:“{{#get}} helper took 383ms to complete”,“stack”:“HelperWarning: {{#get}} helper took 383ms to complete\n at HelperWarning.GhostError (/var/www/ghost/versions/3.20.3/node_modules/@tryghost/errors/lib/errors.js:10:26)\n at new HelperWarning (/var/www/ghost/versions/3.20.3/node_modules/@tryghost/errors/lib/errors.js:66:20)\n at /var/www/ghost/versions/3.20.3/core/frontend/helpers/get.js:171:31\n at PassThroughHandlerContext.finallyHandler (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/finally.js:56:23)\n at PassThroughHandlerContext.tryCatcher (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/util.js:16:23)\n at Promise._settlePromiseFromHandler (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/promise.js:547:31)\n at
Promise._settlePromise (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/promise.js:604:18)\n at Promise._settlePromise0 (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/promise.js:649:10)\n at Promise._settlePromises (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/promise.js:729:18)\n at _drainQueueStep (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/async.js:93:12)\n at _drainQueue (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/async.js:86:9)\n at Async._drainQueues (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/async.js:102:5)\n at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/3.20.3/node_modules/bluebird/js/release/async.js:15:14)\n at runCallback (timers.js:705:18)\n at tryOnImmediate (timers.js:676:5)\n at processImmediate (timers.js:658:5)\n at process.topLevelDomainCallback (domain.js:126:23)”,“hideStack”:true,“errorDetails”:“{"api":"v3.postsPublic.browse","apiOptions":{"limit":"3","filter":"tags:daily-trading-strategy+id:-5f032fb6363aea148716e667"},"returnedRows":3}”},“msg”:“{{#get}} helper took 383ms to complete”,“time”:“2020-07-09T06:10:03.176Z”,“v”:0}
