Static File Hack Updated For Members
In 2018 and 2015 there were articles published for how to serve static files. I wanted to do the same, for my free (and hopefully one day soon paid) members.
For self-ghosters, Nginx can read the ghost cookies to serve files if a member is logged in. However, the cookie name contains dashes. There’s a little trick to map it to a variable Nginx can read.
  1. In your conf file: nano /etc/nginx/sites-enabled/ghost add the following above the server { }
map $http_cookie $ghostly_cookie {
default 0;
“~ghost-members-ssr.sig=(?[^;]+)” $mc;
2. Create your folder under /var/www/ghost/[your folder name]
  1. Under the other location entry add:
    location /media/ {
    if ($ghostly_cookie = 0) {return 401;}
    alias /var/www/ghost/[your folder name]/;
Here are the blog and stack overflow sources for reading cookies with special characters:
Now, I’m working on creating a custom error message for 401 (unauthorized).
Bare in mind that this does not check if the cookie is valid, just that it exists - so it would be trivial to get around this by setting cookies with arbitrary content so long as it has the correct name!
Indeed!
To be clear this was not meant to model a secure system.
The ghost cookies are passed to nginx automatically, so I was curious to see if I could track them. It was a fun little project.
If anyone has any ideas on how to expand this into a secure system, that would really cool. I’d be happy to test it out.
If a non-member tries to download, then they will receive the nginx error page. Haven’t figured out how to route it back through ghost.
