Help me solve Structured Data (Site Name) Issue on our ghost site.
SEMrush detects this as an issue: 2 structured data items are invalid.
Field: Name
Issue Description: A value for the name field is required.
Upon checking on Schema Validator it has NO ERROR or WARNINGS but the site name is missing.
We tried overriding the schema by injecting code, but it still didn’t work. We used AI to help us with this and tried every possible solution, but nothing seemed to work.
We think we need to disable the Ghost generated Schema? Any suggestion?
https://lambent.co - What’s your URL? This is the easiest way for others to help you
Version 5.88.1 - What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
And
Properly Installed/Standard - How was Ghost installed and configured?
Chrome - What Node version, database, OS & browser are you using?
Structured Data missing Name - What errors or information do you see in the console?
Injected Code to override Ghost Generated Schema but still didn’t work - What steps could someone else take to reproduce the issue you’re having?
