I like the new recommendations feature and used it on my blog DJ Booga - it works fine.
I realised some limitations and I like to discuss these with you:
The link you put in first will be the last to show if you add more to the list. It would be nice to have a manual sorting option. I’d fancy a random sorting too.
/ update: I just found out it does exactly that by default
The modal shows only the 5 latest links before the “Show all” threshold comes in. Every click is work and I wished there would be none. Can you make the list as is long as it is and shows every item on it?
The recommendation list lives in the portal modal / layover at the moment. It would be nice to have it as a widget too, so I could drop it on a page or post as well.
What do you think?
