Hi
I’m working with a theme named Clifford
The code of the gulp file is like this:
var gulp = require('gulp'),
sass = require('gulp-sass'),
browserSync = require('browser-sync'),
notify = require('gulp-notify'),
concat = require('gulp-concat'),
uglify = require('gulp-uglify-es').default,
cleancss = require('gulp-clean-css'),
autoprefixer = require('gulp-autoprefixer'),
zip = require('gulp-zip'),
del = require('del');
// Local Server
gulp.task('browser-sync', function () {
browserSync({
proxy: 'http://localhost:2368',
// server: {
// baseDir: ''
notify: false
// open: false,
// online: false, // Work Offline Without Internet Connection
// tunnel: true, tunnel: "projectname", // Demonstration page: http://projectname.localtunnel.me
// HBS Live Reload
gulp.task('code', function () {
return gulp.src(['*.hbs', '**/**/*.hbs', '!node_modules/**/*.hbs'])
.pipe(browserSync.reload({ stream: true }));
// Custom Styles
gulp.task('sass', function () {
return gulp.src('./assets/sass/*.scss')
.pipe(sass({ outputStyle: 'expanded' }).on('error', notify.onError()))
.pipe(concat('main.min.css'))
.pipe(
autoprefixer({
grid: true,
overrideBrowserslist: ['last 10 versions']
.pipe(cleancss({ level: { 1: { specialComments: 0 } } })) // Optional. Comment out when debugging
.pipe(gulp.dest('./assets/css'))
.pipe(browserSync.stream());
// Scripts & JS Libraries
gulp.task('js', function () {
return gulp
.src([
'./assets/js/vendors/jquery-3.3.1.min.js',
'./assets/js/vendors/zoom.min.js',
'./assets/js/vendors/transition.js',
'./assets/js/vendors/jquery.fitvids.js',
'./assets/js/vendors/jquery.ghosthunter.js',
'./assets/js/vendors/jquery.viewportchecker.min.js',
'./assets/js/vendors/prism.js',
'./assets/js/vendors/slick.min.js',
'./assets/js/common.js'
.pipe(concat('common.min.js'))
.pipe(uglify()) // Minify js (opt.)
.pipe(gulp.dest('./assets/js'))
// Production - Compress Theme
gulp.task('zip', function () {
var targetDir = 'dist/';
var themeName = require('./package.json').name;
var filename = themeName + '.zip';
return gulp
.src([
'!node_modules',
'!node_modules/**',
'!package-lock.json',
'!dist',
'!dist/**',
'!.gitignore',
'!**/Thumbs.db',
'!**/*.DS_Store'
.pipe(zip(filename))
.pipe(gulp.dest(targetDir));
// Remove Dist Folder
gulp.task('clean', function () {
return del(['dist'], { force: true })
gulp.task('watch', function () {
gulp.watch('./assets/sass/**/*.scss', gulp.parallel('sass'));
gulp.watch(['./assets/js/common.js', './assets/js/vendors/*.js'], gulp.parallel('js'));
gulp.watch(['*.hbs', '**/**/*.hbs', '!node_modules/**/*.hbs'], gulp.parallel('code'));
gulp.task('default', gulp.parallel('sass', 'js', 'browser-sync', 'watch'));
gulp.task('production', gulp.parallel('sass', 'js', 'zip'));
I’d love to try the solution with your workflow, but I had to understand it first, I have never done that before ^^
