I downloaded the casper theme.
Copy the folder and rename it for my theme.
I follow this tutorial.
In my terminal when i use the : npm run zip i get this result
npm run zip
> casper@5.4.10 zip
> gulp zip
'gulp' n’est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
‘gulp’ is not recognized as an internal command
or external, an executable program or a batch file.
nothing works
And if i use the command : npm install i get errors too
I understood that Gulp was missing, also i installed it
C:\Ghost\content\themes\agenceweb (casper@5.4.10)
λ npm install -g gulp-cli
npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
added 268 packages in 17s
10 packages are looking for funding
run `npm fund` for details
λ npm run zip
> casper@5.4.10 zip
> gulp zip
[11:47:49] Local modules not found in C:\Ghost\content\themes\agenceweb
[11:47:49] Try running: npm install
And after i lunch : npm install
λ npm install
npm ERR! code ERESOLVE
npm ERR! ERESOLVE unable to resolve dependency tree
npm ERR!
npm ERR! While resolving: casper@5.4.10
npm ERR! Found: postcss@8.2.13
npm ERR! node_modules/postcss
npm ERR! dev postcss@"8.2.13" from the root project
npm ERR!
npm ERR! Could not resolve dependency:
npm ERR! peer postcss@"^8.2.15" from cssnano@5.1.12
npm ERR! node_modules/cssnano
npm ERR! dev cssnano@"5.1.12" from the root project
npm ERR!
npm ERR! Fix the upstream dependency conflict, or retry
npm ERR! this command with --force or --legacy-peer-deps
npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
npm ERR!
npm ERR!
npm ERR! For a full report see:
npm ERR! C:\Users\Jean-Mi\AppData\Local\npm-cache\_logs\2023-05-14T09_48_27_752Z-eresolve-report.txt
npm ERR! A complete log of this run can be found in: C:\Users\Jean-Mi\AppData\Local\npm-cache\_logs\2023-05-14T09_48_27_752Z-debug-0.log
I copied the casper Theme and rename as “agenceweb” so i ran my command line from this folder now.
