I created a collection in my routes.yaml file so I can have posts show up with the primary tag in the URL, like so:
routes.yml
collections:
/favorites/:
permalink: /favorites/{slug}/
template: favorites
filter: primary_tag:favorites
Results
/favorites uses the favorites.hbs template
/favorites/{slug} uses the post.hbs template
I can’t figure out how to get the individual posts to use a template other than post.hbs. Seems like tag-favorites.hbs should do the trick, but everything under /favorites/{slug} is still loading post.hbs (and yes, I restarted Ghost). Any tips on how to achieve this?
Hi @coolmoods,
It seems you are looking to create custom post templates.
After you created a custom template you can assign it to any post in the Admin:
Ah, OK. I was hoping I wouldn’t have to make the editors manually choose a template (more room for goofs), but it’s good to know it’s an option.
I found a viable workaround:
Create your various post templates in the partials subdirectory.
Edit your main post.hbs to include the correct template based on tag criteria:
{{!< default}}
{{#post}}
{{#has tag="newsletter"}}
{{> post-newsletter ..}}
{{else has tag="podcast"}}
{{> post-podcast ..}}
{{else}}
{{> post-generic ..}}
{{/has}}
{{/post}}
