Theme templates
Hey folks, is it possible to create a hb template for a specific tag?
Basically I have a tag called “notes” I’d like it to have it’s own template that can be styled separately from the normal tag template
Yes, if you create tag-notes.hbs then that will render as the custom template for that tag :) full template docs:
Awesome, cheers John
