Custom post.hbs
is it possible to create a single post template for styling a specific tag?
Yep:
create a file called tag-{slug}.hbs and that will take precedence
Sorry, I’m confused. Isn’t that the tag listing page?
What I’m trying to do is have a separate single post page for a particular tag.
Say if I have a tag called quotes, and I click into the single post view. I want it to display only the content of the post, not the title or the meta data.
I know you can do post{slug}.hbs on a post by post basis, but I want to do it on a tag tag basis. Something like post{tag}.hbs
I don’t follow on what you’re trying to do?
Go to /tag/quotes -> It displays only post content rather than post meta for every post?
I think that @MayanMisfit wants something like this. All posts that have a certain tag to automatically get a post template. For example:
collections:
  /news/:
    permalink: /news/{slug}/
    filter: news
    template: news
The template for /news/ is news.hbs. But all posts will get post.hbs as template. So he wants to get post-news.hbs for all these posts.
Not sure there is a way to set but I might be wrong. I can only think of using {{#has tag="news"}} inside post.hbs and load from partials a custom structure.
Yes, that’s pretty much it. Could I put like 95% of the post.hbs in to a partial? Well all the styled elements at least? So I’d have a partial called ā€˜posts’ and one called ā€˜notes’
Ok this is sorted now, I was being dense
If I am understanding this correctly:
Is it possible to have all posts with a specific tag to have a different layout?
In my case, I have podcasts in posts. So I create a post and assign the tag ā€œpodcastsā€. Then that post has a title, short introduction and then an embedded podcast link from anchor.fm.
I don’t want to assign post images because I don’t like the big header image for podcast posts. I want to make it smaller and adjust it somewhat.
Have you tried custom post?
https://ghost.org/tutorials/custom-page-templates/
you’d create a custom-podcast.hbs and you can assign it to your podcast posts
