Ghost version: 4.22.1
Node.js version: 14.17.6
sharp version: 0.29.2
ghost doctor check everything is OK:
✔ Checking system Node.js version - found v14.17.6
✔ Checking logged in user
System checks failed with message: 'Linux version is not Ubuntu 16, 18, or 20'
For local installs we recommend using `ghost install local` instead.
? Continue anyway? Yes
System stack check skipped
ℹ Checking system compatibility [skipped]
+ sudo systemctl is-active ghost
? Sudo Password [hidden]
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v14.17.6
When upload new image in the post and visit the page, the resized image url return 404. (eg. /content/images/size/w1140/2021/11/feature.jpg) . I’ve check the folder, there is no image on the size folders but original one.
I’ve tried different themes such as Alto, Casper, the issue still exists.
Can anyone help to solve this problem?
