There is no field "add custom integrations"
installed ghost v2.22.1 plesk server on node js 8.11
everything works, but I can’t configure zapier. can’t get admin api. As far as I understand, it is received through “add custom integration”? but I don’t have one, there’s an empty field below.
Zapier is now configured using an Admin API Key but you’ll need Ghost 2.23.0 or later to see a key on the Zapier integration screen.
Looking at your screenshot it appears that you are on a much older version, it definitely doesn’t look like you are on Ghost 2.22.1, if you were your integrations screen would look like this:
Try clicking the dropdown in the top-right and then clicking “About Ghost” to see which version you are running:
