Trouble upgrading from 3.2.0 to 3.11.0
  • What’s your URL? This is the easiest way for others to debug your issue: https://infosec.theos-blog.com
  • What version of Ghost are you using? 3.2.0
  • What configuration? Production
  • What browser? Firefox
ghost-user@ghost-new-s-1vcpu-2gb-nyc1-01:/var/www/ghost$ ghost update
  • sudo systemctl is-active ghost_infosec-theos-blog-com
    :heavy_check_mark: Checking system Node.js version
    :heavy_check_mark: Ensuring user is not logged in as ghost user
    :heavy_check_mark: Checking if logged in user is directory owner
    :heavy_check_mark: Checking folder permissions
    :heavy_check_mark: Checking file permissions
    :heavy_check_mark: Checking content folder ownership
    :heavy_check_mark: Checking for available migrations
    :heavy_check_mark: Checking for latest Ghost version
    :heavy_multiplication_x: Downloading and updating Ghost to v3.11.0
    A SystemError occurred.
Message: Ghost v3.11.0 is not compatible with the current Node version.
OS: Ubuntu, v18.04.3 LTS
Node Version: v8.17.0
Ghost Version: 3.2.0
Ghost-CLI Version: 1.13.1
Environment: production
Command: ‘ghost update’
Run ghost update with 3.2.0 installed when trying to upgrade to 3.11.0.
What additional steps do I have to take to upgrade from 3.2.0 to 3.11.0?
Kind regards,
Ted
Solved. Followed the steps outlined here:
Upgraded my node version and ghost upgraded fine after that.
