I’m running a self-hosted old version of Ghost (2.36.0), and I’m trying to upgrade it to the newest one. The ghost CLI tool recommends me to first upgrade to the last 2.x version with ghost update v2, so that’s what I’m attempting to do now.
My system node version is 12.22.10, but I’m using nvm so I can easily switch.
If I’m trying to run ghost update using node 10.13.0, I’m getting the following error:
Message: The version of Node.js you are using is not supported.
Supported: ^12.22.1 || ^14.17.0 || ^16.13.0
Installed: 10.13.0
See https://ghost.org/docs/faq/node-versions/ for more information
OS: Ubuntu, v18.04.3 LTS
Node Version: v10.13.0
Ghost Version: 2.36.0
Ghost-CLI Version: 1.18.2
Environment: production
Command: 'ghost update v2'
So I try again with the one that’s supposed to be supported (12.22.1). Then I get the following:
✖ Downloading and updating Ghost to v2.38.3
A SystemError occurred.
Message: Ghost v2.38.3 is not compatible with the current Node version. Your node version is 12.22.1, but Ghost v2.38.3 requires ^8.10.0 || ^10.13.0
Node Version: v12.22.1
What can I do to make it run?
