Trying to run ghost docs locally
I’m trying to run docs.ghost.org locally and ran into two issues:
#Issue 1:
While running git submodule update --init, I ran into this issue. Not sure what it is.
Please make sure you have the correct access rights and the repository exists.
fatal: clone of 'git@github.com:TryGhost/docs-api.git' into submodule path '/Users/svikashk/Downloads/docs/content/api/v2' failed
Failed to clone 'content/api/v2' a second time, aborting
Cloning into '/Users/svikashk/Downloads/docs/content/api/v0.11'...
git@github.com: Permission denied (publickey).
fatal: Could not read from remote repository.
#Issue 2:
Even after running yarn and then copy and pasting .env.example to .env.development, I get
Error: GHOST_API_URL and GHOST_API_KEY are required to build. Check the CONTRIBUTING guide.
- gatsby-config.js:16 Object.<anonymous>
 /Users/svikashk/Downloads/docs/gatsby-config.js:16:11
- v8-compile-cache.js:178 Module._compile
[docs]/[v8-compile-cache]/v8-compile-cache.js:178:30
- loader.js:700 Object.Module._extensions..js
internal/modules/cjs/loader.js:700:10
- loader.js:599 Module.load
internal/modules/cjs/loader.js:599:32
- loader.js:538 tryModuleLoad
internal/modules/cjs/loader.js:538:12
- loader.js:530 Function.Module._load
internal/modules/cjs/loader.js:530:3
- loader.js:637 Module.require
internal/modules/cjs/loader.js:637:17
- v8-compile-cache.js:159 require
[docs]/[v8-compile-cache]/v8-compile-cache.js:159:20
- get-config-file.js:33
[docs]/[gatsby]/dist/bootstrap/get-config-file.js:33:22
- Generator.next
- new Promise
- get-config-file.js:53 getConfigFile
[docs]/[gatsby]/dist/bootstrap/get-config-file.js:53:27
I’m not sure if #Issue 2 is because of #Issue 1. I git cloned from source today. Any pointers on what I might be getting wrong?
Looks like the parent repository is trying to set up the submodule using SSH, but you haven’t set up SSH with Github yet. I think if you follow these guides you should be all set:
Check for existing SSH keys
Generate a new one, if you don’t already have one
Add your key to your Github account
Awesome! Works like a charm now. Thanks @John. :slight_smile:
