Two blogs on single digitalocean droplet
Hey, I’m trying to create 2 blogs at one digitalocean droplet and i’m stuck. My domain https://haluksfix.pl is still pointing to the second blog I had installed on this droplet at domain https://bieglygrafologblog.pl. I couldn’t initialize the SSL setup.
You have something misconfigured in Nginx or DNS, which is why one domain is redirecting to the other, and why you’re getting the Let’s Encrypt error–that message occurs with repeated failures when rate-limiting kicks in.
But it looks like you got it working–since both domains work independently now–so, please mark the thread as solved.
I had to disable cloudflare, and after this install SSL.
